Have 2001 Exp (5.4L) with 165K. Have following symptoms:
1. Hard starts only when engine cold - starts OK when engine warm.
2. Idles at normal RPM in park (700-800 RPM) but idles rough.
3. Seems to shift OK up to O/D but not smooth
4. Rough idle (in drive) at a stop.
5. Lack of power - acceleration not smooth
Symptoms seem indicative of bad COP. Had steady check engine lite which would intermittently blink when accelerating. As of today, have not been able to pull codes as they were cleared due to dead battery and havent been able to get OBD to re-establish fault codes.
One other symptom - with engine idling, there is a loud "buzzing" noise which seems to be coming from either cylinder 1 or 2 (passenger side counting back from front of engine). Never known failed or failing coils to buzz - could it be injector going bad?
Drove vehicle some more this evening to try to get CEL to come back on and hopefully retrieve fault codes. So far, unsuccesful to get CEL to come back on even though running poorly.
Thanks in advance for any thoughts/advice!!
