2001 Expy Knock on acceleration
VictorDuwon
Galveston
Howdy everyone,
I have a 2001 Expedition 4.6L XLT, rwd, 186K miles. A few weeks ago, while driving, I heard a thump toward the front of the vehicle, then the knocking started. It is a definite metallic knock which only occurs above 1500RPMs while accelerating. I was doing ~20-30mph at the time. When I let off the accelerator, the knock went away. The truck did not throw a code until I got home, then it was P0301.
So, I opened her up, and replaced the #1 plug and COP. [I bought a full set of plugs and COPs a few years ago, and had leftovers.] The knock persisted.
Next, I replaced the #1 fuel injector with a new one. The knock persisted. Not only does the knock return whenever I accelerate, but after a few minutes the P0301 returns too.
To clarify, it is definitely a p0301 and not a p0300. I've replaced all the components there, and don't know what else to do. This is my daily driver. I'm a decent shade-tree mechanic, but this is straying outside of the things I know how to do. Any advice would be appreciated.
TLDR;
Truck : 2001 Expy 4.2L 186K Knocking on passenger side of motor
Symptoms : The knock can't be heard while the engine is idle, only on acceleration over 1500RPMs.
Low speed acceleration - Knocking
Coasting regardless of speed - No Knocking
Unsuccessful attempts to fix the P0301/Knock:
-Replaced plug
-Replaced COP
-Replaced Fuel Injector
-Fresh Oil/Filter change.
00XTL
North Carolina
If you cant hear the knock while in the vehicle then pop the hood and remove the 4.6L engine cover. With the engine running and in park use the throttle body to rev the engine and listen for the noise. If you can hear it the get a stethoscope if you can or a long screw driver and place it in different spots to hear the noise more clearly. It’s coming from the bottom end that put your listening tool up to the oil pan or where the oil pan and engine meet. If you cant hear it the try putting the truck in gear and power braking it.
You can also use a screw driver and listen to make sure the injector is working.
If you do all that and still no knocking then i would focus on why its miss firing
VictorDuwon
VictorDuwon
Galveston
Thanks for the response 00XTL. I can hear the knock inside the vehicle, however when I have it in park or neutral, I hear nothing inside or under the hood. Its only present when moving under acceleration above 1500rpms. I bought a stethoscope as you suggested and there is a regular tap from the #1 injector when I put the probe at the base of the injector. It is loudest when touching the #1 injector and less noticeable, when repeated at the other injectors. It is not the rapid knocking I hear under acceleration, but more of a scaled down tap-tap-tap.
The #1 injector is less than week old by the way.
VictorDuwon
VictorDuwon
Galveston
Thanks JamacaJoe. Is there a way I can verify that? Would that coincide with the P0301 code that keeps returning. It is the only code that gets thrown.
JamaicaJoe
Oviedo FL
I am just throwing that out there as the engine can log a misfire for any reason including loss of compression on a cylinder. Under load conditions are going to stress things so, if the exhaust valve is gummed up or has a weak spring it may dwell a bit longer.
What you are complaining of is disturbing enough that I would recommend removing the valve cover to inspect the valve train and also a borehole inspection of the cylinder.
Also have the oil pressure measured.
Get it towed in , don't risk damage.
Sent from my SM-T350 using Tapatalk
Trainmaster
Old School Member
Rockaway Beach, NY
I assume is a knock knock knock and not a single knock and that the P0301 comes back. And that would mean it's in the motor. A single knock can be in the drivetrain, possibly the driveshaft slip joint in need of lubrication. If that were the case the code would be a coincidence.
If it is in the engine, I'd go with 00XLT's advice. You have to find out if it's valve or lower end related. As JamacaJoe said, it could be a valve. Or it could be a rod. You can take off the valve cover and check valve springs, etc. Then you follow the routine to check valves using compressed air and all that stuff...
A knock's not good.
VictorDuwon
VictorDuwon
Galveston
I agree Trainmaster, the knock is bad. I have some supplementary information. Driving today @60mph, on cruise control, the RPMs jumped to over 3000, the CEL began to flash, the knocking was fast and higher pitched, and there was an intermittent thunk separate from the knock. This sound came from what felt like, the driver’s side but low, beneath my feet. The ride during this ‘fit’ was rough, then another random thunk, and the RPMs went back to normal. The code thrown was still P0301 [CYL#1Misfire]
I have my Chilton manual, and will start learning how to remove the valve cover. Thanks for the advice. If anyone has any pointers for doing this job I’d really appreciate it.
Trainmaster
Old School Member
Rockaway Beach, NY
Valve cover comes right off. Just a lot of stuff to get out of the way. Watch a couple of videos about cam followers. They break and/or fall out or jam up. You'll want to look carefully at them for wear or damage when you're in there. Thant's one thing that can jump out of place, hold a valve open/closed then jump back in. Not too hard to fix.
A broken valve spring may be hard to see.
A longshot: If you didn't use a Motorcraft coil, you might try swapping your new #1 coil with another cylinder. Many cheap ones are bad out of the box.
VictorDuwon
VictorDuwon
Galveston
I'm researching Cam Followers, and how to remove the coolant hoses and other obstructions. I will begin working on it this afternoon and update here. Thanks again.
VictorDuwon
VictorDuwon
Galveston
So far, I've disconnected the heater hoses, but I can't seem to get the wiring harness bracket disconnected from the valve cover bolts. Its plastic, and I can't seem to get it up without breaking it. Is there a special tool or technique for this?
Edit:
Nevermind, I figured it out. So far so good. Is there a logical reason some of the bolts have the shaft and others are just a 8mm bolt?
JamaicaJoe
Oviedo FL
Well indeed, there's your problem!
That was your original thump most likely.
Was the valve keeper still in place?
JamaicaJoe
Oviedo FL
Now I am nervous.
I have an 01, 4.6 L with half the miles. But a while back, I took it to AutoZone to have the alternator tested and the "tech" over revved my engine to the point I am sure the valves were floating. No problems so far, good oil test results, but the valve train is is the weak point in these engines,.
JamaicaJoe
Oviedo FL
VictorDuwon
VictorDuwon
Galveston
I didn't see anything like that. I'll feel around there with a magnet this morning and see if I can find anything.
I'm trying to find a replacement spring also. Will I be able to replace this without removing the shaft? I can see how the rocker arm and spring fit beneath the cam, but now that you mention missing pieces, I'm not so sure.
VictorDuwon
VictorDuwon
Galveston
I didn't find anything in the wells, but where the timing chain is I did see what looked like a partially ground up piece of curved metal. One of the keepers I think. I went for it with my magnet, but lost it.
The valve seal does seem to be intact however.
JamaicaJoe
Oviedo FL
So the valve did not drop? Try to find all the metal bits. An oil and filter change will be on the list.
I can't advise the best way to proceed. These are wear parts, at that mileage, you may need to replace all the springs and followers. Otherwise you could change what's broken and keep your fingers crossed.
There is an identical recent thread on broken cam followers on this board. In that case the follower roller siezed up, scored the cam.
