2002 cruise (no)control????
radar
bellaire ohio
I have a 2002 Expedition 4x4 Eddie, the cruise control doesn't work. I replaced a clock spring, tried new set of buttons, servo & did diagnostic test (lite flashed with OFF & ON buttons only) did nothing with others. We used ohm meter & have connection from buttons when depressed to the servo.
Press off & any other buttons the Horn Blows!!:wtf2:
Any info of where to look would be a great Help!
radar
radar
bellaire ohio
I found the problem with my cruise control!
It was the pressure switch on the front of the master cylinder. $25.00 from my Ford dealer fixed it.
How to check it, unplug it & jumper wire the plug terminals & give it a try.
1997SCEBFEX
Northwest Panhandle
this was a major recall item some years back based on fires starting as the membrane deteoriated igniting the fluid/vapors.
glad you figured it out!
PanHandler.
brockncole
Illinois
Fix it my cousin torched his 150 after fixing all the fuses and not getting the recall done.
brockncole
Illinois
My 2001 F150 did too but then after about 4 years it quit working because the "fix" failed and I finally fixed it by replacing the recall fix. With the new pressure switch.
