2002 Transfer Case Lever Positioning Sensors - What Do They Do?
snoopy2u
north carolina
Recently had the tc shift motor replaced. After the installation, mechanic says he could not find 12v at the motor. Fuse 104 is good. I can hear the relays under my dash clicking when i turn the key "on". Was checking the wiring to the new motor to make sure the mechanic did not make an error in the re- wiring of the motor's plug. Noticed two sets of three wires coming from the TC end. The lower harness appears to be a " transfer case lever positioning sensor". And, it appears the other three wire harness is also a sensor.
Can anyone tell me what they do. How can I check them for proper operation? Could these sensors be "blocking" or interrupting the 12v to the shift motor??
Where can I find the GEM?? Is the GEM a module that would be suspect. Do they go out frequently??? Can I change out a GEM module?? without any re- programming???
llldatlll
