2003 5.4 2 valve rough idle, hesitation when stepping into it and low power no codew
bydptrsb
Bellevue, Ne
I have an 03 expy with the 5.4 that has a rough idle, low power (0-30 in 20 seconds) and no codes I replaced the oxygen sensors, MAF sensor and the throttle position sensor. Could this be timing or is it IAC? Is it something else?
Hamfisted
Ft Lauderdale
How old is the fuel filter ? If you have a fuel pressure test gauge, what kind of fuel pressure are you seeing at the fuel rail schrader valve ?
To release the fuel lines off the filter just push the blue buttons in on the quick connects ....
Motorcraft FG-1063 fuel filter....
B
bydptrsb
Bellevue, Ne
So I have changed the fuel filter earlier this year. I think 3 or 4 months ago and I don't think I have a fuel pressure test gauge but I think I will buy one
Ratz669
Not the exact symptoms but, I had something similar - hesitation when accelerating.
For years, I tired to pinpoint it - changed the fuel filter, map sensor, throttle body, etc. It wound up being a cracked intake manifiold cover. Upon extensive reserach, this apparently is not all that uncommon as Ford uses a plastic cover meaning that it is susceptible to changes in temperature and can crack.
I have a 2005, btw
GaryH
No codes? Not even misfire codes? Possibly clogged cat? Check for banana in the tail pipe :).
Broncoholic
Space Coast, FL
When is the last time you changed the spark plugs or coils? Or at least check the coil boots?
Also, I've had a misfire steadily getting worse on my 03. From when I first noticed it, it took over a week of driving to work and around town (probably 70 miles) before it finally set a code for misfire on cylinder 2. Mine wasn't as bad as yours though, I could get still accelerate pretty well.
FukNshT
