stevebigos
Hi folks, new guy here. I just bought a 2003 EB Exp. The 4 x 4 Lo works fine, clunks going in and out of 4 x 4 as it should, and all 4 wheels are powered. But I have no 4 x 4 Hi. The 4H dash light comes on when I start the vehicle, then goes out as it should. I have tried various combinations of moving the dash switch to 4 H when moving, stopped, engine on/off, park, neutral, etc, no go. I do hear a faint click inside the rear drivers door pillar (in the seat belt winder area) when switching to 4H, so something is happening, leading me to think the dash switch is most likely functioning. The 4H light never comes on and no transfer case clunk. Fuses are all good.
I looked for vacuum hose leaks and found nothing obvious. Also looked over the transfer case motor and don't see anything obvious.
Looking for advice, also looking for theory of operation of the transfer motor, and advice on the AWD position as I see no indication that it is or is not working either. Also would like to know the steps for changing both diff and transfer case fluid. I did buy the Ford friction modifier for the diffs.
Any help is appreciated. Thanks.
