2003 Ford Expedition 5.4 EB 200K miles. strong crank with no start. New fuel pump, maybe a ground ?
D
David Carelli
canfield ohio
Ahhh... Yes, on the 2003 that is built into the fuse box. I still cant believe with all the guru's on the site, no one can tell me where the ground is located for the fuel pump.
D
David Carelli
canfield ohio
Thank you sir. Well its running !!!! I changed the fuse box and it started right up. Confusing though as i jumped the relay and it didnt run the fuel pump. So i changed the Fuel pump and nothing, but started after the fuse box change. On the back of the fuse box, lower forward connection there is only one wire running to the connection but it had come apart. I wonder if that was it. Any one know what the connection on the backside lower forward with only one wire is for ?
sharprd65
