2003 Ford Expedition Fuel Pump Relay
jakejbyrd
South Carolina
I have a 2003 Ford Expedition that stopped running. I could tell it was a fuel issue as it would crank but not start. My original thought was fuel pump. I ran voltage straight to pump and it ran and the truck started. So I removed the fuse panel and found the relay was bad. I replace relay, put everything back together and the truck started and ran for about 15 miles. Then truck repeated same issue. The problem is I'm not getting an error code so it's hard to troubleshoot. Any suggestions on where to go next? New relay looks good, as I did remove panel again to take a look.
riphip
Memphis, TN.
The relay burns from the back of the board where it mounts (soldered). You have to pull the Fuse Box & split the boards to see this. Do a search in upper right for 'fuel pump relay' & there is a lot of info & pictures
J
jakejbyrd
South Carolina
I did all that. Seems to be something causing the relay to go bad as I have put in 2 relays and getting same issue.
Hamfisted
Ft Lauderdale
If it's the original fuel pump it can be drawing so many amps it's frying the relay. Are you able to measure the amp load when you jump the fuel pump ? A new fuel pump will probably help.
