Washer System
The windshield washer or the rear window washer is activated by the internal wiper motor modules when it receives a ground from the multifunction switch between the washer inputs. Dependent on the correct ground, the internal wiper motor modules activates either the windshield washer or rear window washer relay (internal) by grounding the respective relay coil. When either relay is activated, it connects voltage to the washer pump while the deactivated relay provides ground to the washer pump. In this manner voltage polarity is reversible to achieve directional change of the washer pump and washer fluid.
