C1998 Module Calibration Not Complete ABS Module Go To Pinpoint Test P .
PINPOINT TEST P: DTC C1998 MODULE CALIBRATION NOT COMPLETE
NOTE: Stability assist lamp will flash when calibration is required. IVD calibration is required after certain DTCs are cleared.
NOTE: Ensure the vehicle is on level ground, not on a hoist, before carrying out the ABS module calibration.
Test Step Result / Action to Take
P1 CHECK FOR DTCS
Connect the diagnostic tool.
Key in ON position.
Retrieve DTCs.
Is any other DTC retrieved with C1998?
Yes
GO to the appropriate pinpoint test for the DTC.
NOTE: Some of the pinpoint tests recommend IVD calibration prior to any further diagnostics, in this case GO to P2 .
No
GO to P2 .
P2 ABS CALIBRATION
Start the engine.
NOTE: Be sure to rotate the steering wheel lock-to-lock during the calibration of the ABS system.
Carry out the ABS module calibration per the diagnostic tool instructions.
Did the calibration complete for all of the stability assist sensors; and did the stability assist lamp stop flashing and go off?
Yes
GO to P3 .
No
GO to P4 .
Some concerns will cause the calibration not to complete. If sent here from another pinpoint test, return to that pinpoint test for further diagnostics.
P3 CLEAR DTC C1998
NOTE: You must clear DTC C1998 after the completion of the calibration.
Key in ON position.
Clear the DTC.
Did the DTC clear?
Yes
TEST DRIVE the vehicle. REPEAT the self-test.
NOTE: If sent here from another pinpoint test, return to that pinpoint test for further diagnostics.
No
GO to P4 .
P4 MONITOR THE STEERING WHEEL ROTATION SENSOR PIDS
NOTE: You must clear DTC C1998 after the completion of the IVD calibration.
Key in ON position.
Monitor the ABS module steering position sensor PIDS while rotating the steering wheel clockwise and counterclockwise.
Are the two steering position sensor PID values switching as the wheel rotates?
Yes
Go To Pinpoint Test H .
No
Go To Pinpoint Test G .
