2004 expedition Bearing replacement
danclow
alberta
There has been a bit of a growling noise while I drive down the road, I jacked it up and I can't feel any play in the front wheels but there is play in both rear wheels, I have found lots of info on changing front bearings but not much for rear bearings, can anyone point me in the right direction. Should I get a tech to look at it to make sure it is bearings
Bedrck47
Elizebethtown, PA
Raise the rear and grab the tire at the 3 o'clock and 9 o'clock position and move them side to side There should be no play ir the rear wheels
Play in the rear wheel does indicate bad wheel hub bearings
There are a few videos on youtube on how to replace them
