2004 Navigator 4.6 engine getting hot
MrJr
I have a 2004 Navigator hitch a 4.6 engine . It gets hot after running a few
Minutes. I'm needing to know where to look for the problem.
It does not show a leak .
Jb14
California
Your question is a little broad can you narrow down like Miles on vehicle, what have you done to cooling system.
Possibilities:
  • Radiator Fluid level (if your heater not blowing hot, low fluid is a symptom)
  • Thermostat bad not opening (have you had it changed)
  • Clutch fan
  • When was the last time you did a flush
  • Radiator could be bad
Etc..
03 exp
Check the coolant make sure is not low, possibly thermostat if it overheats pretty quickly!!
docraymund
philippines
Check components first for proper operation. Dont change parts unless they are proven defective.
