Retiredusps
Wife's 05 did same thing turned out to be colapsed hose from frame to caliper.replaced both sides fixe I did same thing new pads calipers rotors, stilll shook the hole truck hoses fixed it.
Had the BAD shake on my 04... Could have sworn it was the front rotors... IT TURNED OUT TO BE THE REARS ! No shake in the steering but the vehicle shake was SEVERE !!! Been fixing my own stuff for DECADES ! This one shocked the S out of me !!! On another note... Check all your Brake lines !!! They love to rust out and BLOW !!! I had to change EVERY LINE after 2 seperate close calls ! The one that runs across under the engine to the passenger front was the worst ! At the age of your truck this is a MAJOR concern... Custom cut all new lines using copper coated nickel brake line... To those who point you to an ABS Sensor HEADS UP If the sensor is shot the wheel bearing/hub is guaranteed right behind it ready to go... You put a new sensor in and it fails within a month ! The Wobble is almost undetectable but enough that the sensor gets ground up by the hall effect vane inside the hub scraping on it... The hubs are a **** to remove !But wouldn't that tend to make the steering wheel shake also .
