jimatty
I have a 2004 Eddie Bauer - big engine - recently, while just driving down the road, the engine will shut off. When it does, the battery light will come on, as well as the check charging system warning, however, battery and alternator check good. There does not seem to be any pattern as to speed, what equipment is being used. When this happens, you can put it in neutral, turn the key all the way off and then restart it, while still rolling down the road. It will not restart, unless the key is turn completely to off. After it restarts, the battery light will come on and off for a while and the check charging system warning will come on and off. It may drive 3 or 4 days with no problem, but it might die four or five times in a trip of a couple of miles. You can start it and jiggle all the electrical wires under the hood and it won't die. But it sure seems like an intermittent electrical short of some type with the battery light and check charging system warning. It was throwing code for crankshaft sensor, so replaced that (and it was cracked) but then it died again next time I drove it. thought it might be key chip, but it does it with either key. Ideas?
