2005 Eddie Bauer Booster Check Valve
kylejw
Canada
Hey All,
I have a 2005 Eddie Bauer with AdvanceTrac
My issue is very weak braking power when first pushing the pedal. If I leave my foot on it for a second and push further, it grabs nicely. Pedal is very firm with engine off so I believe this to be a vacuum issue.
I'm seeing no vacuum from the intake port at idle (I think this is normal)
I see 19 inches from the manifold (at 3000 ft elevation so it's probably more than that)
However I noticed that the manifold vacuum is sucking all the way through the booster check valve and into the intake. I think this is bad, because all my vacuum is presumably sucking from the intake instead of the booster! Essentialy, air flows between the two yellow ports on the check valve.
Anyway I wanted to confirm how this 3 hose check valve is supposed to work? And is there anywhere I can buy one? The dealer said they aren't available from ford but he gave me a part number that looks totally different - 5L1Z-2365-A
Thanks
K
kylejw
Canada
So the check valve in this case is called an aspirator and it looks like it follows the design here:
One the venturi effect gets involved, Id normally head for the hills . But I'm going to keep testing here.
K
kylejw
Canada
Ken0356
Illinois
I have same issue with my 2006 XLT Expedition. Were you able to locate a replacement aspirator valve?
sharprd65
