hancock1228
I have a 2005 XLT that when the 4x4 switch is placed in the 2H position it still turns the front drive shaft. I verified this with the vehicle on a lift. The front tires do not turn (front driveshaft does). When placed in AWD / 4H / 4L the front tires turn. I believe the IWE's are functioning properly. I thought I understood that the clutch in the Transfer Case should not allow the front driveshaft to turn when in the 2H position.
1) Does the TC clutch disengage the front driveshaft when in the 2H mode?
2) If yes, mine must have a problem. How would I diagnose the clutch in the TC?
