2006 RF brake line front crossmember
Roindhouse
Ga
Have a 2006 4wd limited
The brake line from the abs box going to the right front wheel , has burst , at the lowest part where it goes across the front frame crossmember next to the steering rack.
Evidently the plastic anchors on the crossmember rubbed a hole in it .
Anyway .
Has anyone ever replaced this line ?
I can order the entire line from the abs to the wheel but
Is there anyway to replace the entire line ?
I don’t see any way to get it out ,
And frankly I don’t see any way to have enough room to repair the line that’s in there with a flaring tool and
A splice .
Any ideas ?
Thanks
Hampton, VA
my abs module went bad and had to be replaced but i paid for the work so i cant tell u anything on it...i want to say that when i asked about the work entailed they did say the entire system had to be purchased and not just the abs module...meaning the lines came with it...check with ur local shop (not dealership) to see what they say
R
Roindhouse
Ga
Just ordered the nice Eastwood flaring tool .
Will get some nicop line and reuse the fittings from this broken line to make a new one .
Retiredusps
N.J.
I purchased 2 lines and a flare union started at wheel and worked forward. estimated length to buyhard part was up by ac. After I was done noticed it is possible to run it behind front cross member alot easier
r98exp1
