2007 5.4 V8
chuckex
Shadyside ohio
I have an oil leak on the passenger side of the engine, just started, noticed some smoke, I know this just started. Any ideas or thoughts? Thanks Chuck07 expedition.JPG
ricco4592
Oklahoma City
Cant really see anything from your picture, but if its smoking oil is getting on the manifold prob. Would suspect valve cover gasket
richs fishes
Long Island, NY
I'd guess its actually coolant leaking. Directly above what looks like the wet spot (presuming thats what you're talking about), is the plastic "T" connector on the heater hose which is prone to failing on these engines.
The dorman replacement part is usually considered the best option. https://amzn.to/2vPG5O5
Blksmk
Canada/USA
You sure it's nice a minor coolant leak?? From the t hose above the leak
2007Limited
FL
T fitting. Doorman sells just the T cheap. Not too hard to swap the whole thing.
