2007 power door locks
tracygto
Deshler Ohio
I have a 07 expedition the power door locks work with key fob but not with door lock switch inside. I checked both switches and they are good. Door locks work on all 4 doors and there is no hesitation when locked and unlocked with key fob?????
05expedeb
Medford NJ
Sounds like a bad door lock switch Will the switch unlock the doors if you were to have them locked while your inside the vehicle.?
05expedeb
Medford NJ
There is a lock/unlock switch on both front doors. Are you having problems with just one or both sides
. If just one side, which side?
T
tracygto
Deshler Ohio
I have checked both door lock switches out and they are OK and they will either lock or unlock. I forgot to mention a key part in all this. One i went through owners manual and tried the procedure to make them work it did not and this was a sheriffs vehicle. I was told i had to take it to dealer to get locks inside put back in use???
bonkers
Syracuse
Just curious - did you ever find a solution? I have the same problem - keyfob works fine, so does door keypad. Can unlock, but not re-lock with either door switch.
