Well I have to say, it's bloody awkward to change the electric motor, you have to completely remove the step (Only 8 bolts) and disconnect 1 electrical plug. I then had to remove the 3 bolts that secure the motor to the step mechanism and it looks like the motor and gearbox should just pull off, but I could NOT get it to release (yes I removed the wedge that locks the output shaft to the step mechanism, but try as I might the motor would not come out. Ended up having to cut the output shaft from the motor unit with an angle grinder, then with the motor off, I could tap the remains of the output shaft out in the opposite direction to what FORD intended!! The new unit was greased up and mounted very easily, and I then bolted it all back to the car, that's when I discovered the wire leads are about an inch shorter than the leads on the original unit, this means the plug on the end of the wires would not meet the clip on the chassis to secure the plug from vibration!! I connected the plug and then secured it with cable ties, not as tidy as the original ford clip but just fine!! The motor unit seems a little less solid than the ford unit (just a feeling!!) but works perfectly, is nice and smooth and much quieter than the old unit!! For me it was a complete success and took about 1.5 hours due to all the issues of getting the old motor unit drive shaft to come out!! I will open the old unit up and see what has worn, but for $70 this seems a good compromise, the proof will be in how long it works for!! More than 6 years and I will be very happy.
Gary
