2010 Expedition XLT EL - Truck does not accelerate enough
nooruls143
Saudi Arabia
Hi,
I have a problem in acceleration, the car does not pick up faster and is slower than normal. It does not misfire but it just feels like it is held up when I press gas. Engine RPM on neutral is good. If I start my car in morning, it runs fine but as soon a engine heats up, the problem appears. I took to the work shop, they found no error codes except for low voltage for PCM. There is no indication of any plug failure or coil failure. They reprogrammed it but still the car remains sluggish. I changed the car battery 3 months back and changed the gear oil very recently.Any suggestions?
My car is only 56900 KM
Thanks,
Noorul
Newport News, VA
i've spent time in saudi arabia...being in saudi arabia you have sand storms so make sure your intake is clean and clear of dirt/sand
Stoned06
Milwaukee
First thoughts would be fuel filter and air filter. A shot in the dark would be to check the power pedals and make sure they are not all the way down. The gas pedal gets restricted on full travel if they are all the way don preventing a full power acceleration.
N
nooruls143
Saudi Arabia
Thanks,
Apparently, it needed throttle body cleaning. But I think I needed to change fuel filter also as it still does not get enough power and it jerks while driving.
