2011 Expedtion Limited going into Limp mode and traction control light on.
drjaysully
Lafayette,LA
I have a 2011 Expedition el Limited that keeps going into limp mode and unable to clear code bc it can't connect to the PCM. I have replaced the throttle body as suggested form the forum. I have replaced the spark plugs to. It seems to be worse when in rainy conditions. Any idea what else I need to fix to clear this up. Also, the traction control light is constantly on and the button on the dash is not responding. In the setting I can not turn the trailer sway on. I don't want to keep wasting time throwing parts at it. Any suggestions would be very helpful. I am thinking the sensor inside the transmission is going out or shorting out. Please help with this problem. Thank you.
