2016 Brush Guard?
Idrenak
Liberty
Looking at options for a 2016 Brush Guard and not finding much. Does anyone know if the front of the Expedition is the same as the F-150 on the 2016 models?
carlos08
Fl
No idea, but have you tried checking ranchhand and fleetsafety. They offer grille guards.
Newport News, VA
no clue...ur one of the 1st with the 2016...only a could of u here so its new territory...call the companies that u find and ask if they have anything or call the companies that make for the F-150 and see if theyre compatible...I would think they are the same but u never know with ford
Flexpedition
midwest
99% of brush guards & bull bars mount to the frame, replacing the front tow hooks as they use those mounts. That said, the Expedition tow hooks haven't moved since 2003. So any guard 2003 and up should fit. The fascias have changed a few times since 2003, but not the underlying frame. Atleast for the most part the frame is largely unchanged.
F150 frame shares nothing with the Expedition - its not a stretched or modified version, etc. So I would be surprised if the width between the two is the same, which is the key to grill guard applications. Even if it were the same, the F150 has a hood with integrated grill. That design calls for F150 guards to pushed further forward in the center in order for the hood to open.
The only trouble you might run into is guards which have upper support brackets that mount to the radiator header panel. Often these can be omitted.
My local county Sheriff Dept has 2015/2016 Expeditions as well as 07+. They all appear to use the same push bumper attachment, if that helps any. I thought they were Go Rhino, but their website doesn't mention Expy.
1oldtimer
Va
I just looked up the part no's for a 2016 F150 and 2016 Expedition and the same Guard for each is different. So, no they are not the same.
As far as the Expedition and F150 frames not sharing anything; welllll, not true. The frames actually do have a lot of the same pre drilled holes in them. For example, I know that the skid plates mount the same and right off, I cant think of what else, but there are a few other items that to fit the same.
