2016 Expedition Strut Replacement
RenegadeBad_Dog
South Carolina
So the time has come the old girl has 80,000 miles on her now and she's in need of some work. I'm just wondering what brands people have used in the past on there rides. I'm kinda leaning towards the bilstein 5100 but I would love to hear people's feed back.
Sent from my SM-G973U using Tapatalk
3tonsoffun
5100
Better ride quality
Option to lift it a little
And it’s Bilstein, can’t go wrong with them
David1
Pa
Just put Rancho rs9000 easy lift, on my 2010 EL limited, with 145,000 miles. I am not sure if the limited used different struts or spring rates. IMO Other than the height, the only noticeable difference for me was cornering, bc they are new springs. These are adjustable dampening, I used setting 3 in front 5 in rear.
If I didn't have a bad upper control arm and inner tie rod, I would have been disappointed wasting the time and money.
The OEM parts seem to hold up pretty well overtime and mileage
3tonsoffun
This post is regarding a 2016, completely different strut setup
Jeremygsu
Florida
Are the struts really worn out at 81k already? That seems premature for them to be worn out that earlier to me. Wow.
David1
Pa
It is in the 3rd gen 2007-2017 post. How much could change ? I hope the newer vehicles are still using Independent suspension.
07navi
Mt.Shasta California
I am wondering how people gauge the shocks to be worn out other than the obvious leaking. Does the truck bounce once after hitting a bump? Twice? Does it seem to ride wishy washy or does it really ride worse than it was, and worse than it was when? Maybe they are comparing to another vehicle or their wife's comments. Does it really need shocks/struts?
3tonsoffun
Specifically the lower strut mounts for front suspensions. Bolt pattern changed from a single bolt that ran horizontally through the lower shock mount to the new design for 15s and up that now have two bolts that are pressed vertically through the top of the lower strut mount. Some setups that are able to run on 2007-2014s WILL NOT be compatible with the newer 15s and up. Thts what I meant
David1
Pa
Yes I was trying to relay that. I figured if one control arm went the opposite side is probably close also, so I did both. I have terrible luck, and decided if I just do the control arms a few months later a strut will start leaking. It was easier to talk myself into preventative maintenance or "making the truck better". I found after 10 years and 145K miles the springs and struts seemed fine compared to the new. IMO
07navi
Another problem is; unless you are the original owner you usually don't know what was done. I just bought a truck a month+ ago and it was on consignment at a car lot (got super deal) but I never even saw the seller. I don't even know if it has the new style spark plugs in it, or if they replaced the phasers this year, etc.
Qatarguy
Qatar
Hi OP
i replaced my struts with Monroe quick struts. Cheap and do the job well. I drive on-road only and the ride is comfortable.
RenegadeBad_Dog
RenegadeBad_Dog
South Carolina
Hi everyone thanks for the comments. I see a lot of people asking if the truck even needs struts. Short answer our roads are some of the worst in the country. So I've been able to tell that they aren't what they used to be. Also the breaks are about to be replaced and its in need of the basic service I've also seen quite a few owners switching to the 5100s so I figured I might try and tackle a few things all at once. If not atleast I have the knowledge for future reference.
No members online now.
AlvinWestley
