mjp2
I don't believe the relay and hood plunger are utilized. If you're pulling 12v from the dash then use the power point as it has a bigger fuse.
As for switched power, I used an add-a-circuit on a fuse in the passenger kick panel and it's worked well. I can grab some pics if you're interested in that approach, but that might be moot since you can just tie into the wiring you're going to be installing anyway.
