2016 XLT - Replaced Park Assist Sensor and it triggers like crazy
developer
NY
I saw a lot of thread about adding parking sensors, but no 3rd gen replacement...
My rear-left park assist sensor died and it threw a code. I purchased a set of 4 on eBay. They came in black, so I put a very light coating of magnetic metallic touch-up on one and replaced the defective one with it. The code is gone, but the new one is very sensitive. Way too sensitive. From what I see, they may be matched in 2's. Two for the left rear and two for the right rear, but I'm not sure. I haven't tried replacing the one next to the failed one, which is on the shotgun approach list. Also on the list is wondering if FORSCAN (need to get latest version and spreadsheet) has a setting to change the sensitivity level of the sensors. You might think the paint is the issue, but there is no alert when in a parking lot with nothing in it, so I think it's working, albeit too well.
Does anyone have experience with this repair? Is there something that I can do? Thanks.
99WhiteC5Coupe
I don’t have experience with the repair.
Why didn’t you use an OEM Motorcraft / Ford sensor? The list price for them is about $85.
rslynes
Wisconsin
a set of 4 on eBay.
That could be the problem, too.
Go OEM from a real dealership or reputable parts source.
D
developer
NY
Just an update...
The (apparent?) issue is that the PAM (Park Assist Module) has some sort of persistent calibration memory which is set when these are put into service. Using forscan, I checked the PAM for errors (none) and then I did a forced reset.
Now they work normally.
