I have heard of people going to Rotella because of this. It is engineered to be a diesel oil. The additive packages (Not just ZDDP) are going to be different because of this. If I recall, the biggest difference is in the type and amount of detergents used.I found Rotella has a lot of ZDDP and is readily available here. Thanks!
Nor do you have a 3d Generation Expedition the owners of which are the audience for this section of the forum.I change my oil every 3000 and my oil reading says ....oh wait, my truck doesn’t have an oil life reader.
-- Chuck
Rotella sounds heavy duty but it's not for gas engines like Greg said. Don't use it, you wouldn't use GM transmission oil in your Ford would you?...………….bad idea.
Could be but why would you?
Rotella may indeed be used in both gas and Diesel engines.
https://en.m.wikipedia.org/wiki/Shell_Rotella_T
https://www.bobistheoilguy.com/foru...otella-diesel-oil-in-a-gas-engine#Post2237325
