2017 Expedition Limited 13K and Torque Converter Shudder?
jrc50
Mobile, Al.
My 2017 Limited Expedition built Feb. 2017 (2WD) Greeted me at my return to Pensacola Airport last night at midnight after 2 weeks sitting. Unfortunately after about a mile of slow driving away from the parking lot got the first shudder, seeming to feel it was kicking out of gear (it was in Drive position for shifter). Then in short order it continued to shudder. At that point (even my wife noticed something totally wrong, we had been travelling much of the day coming from Utah and were tired), we were both worried given the time of night and we were 40 miles from home, now nearing 1 am. Even though the engine had been running long enough to warm up feathering the gas pedal did nothing to help so I pulled it into Manual and dropped the gear to 4th and that stopped the shuddering and I gradually brought it up to 6th then over to Drive at about 60 mph.
After that it ran home ok on I-10 with no further incidents. Went out this am to check the transmission fluid and Much to my surprise there no longer is a Dipstick for checking transmission fluid so I could discuss issue with a bit more intelligence with my local Ford dealer who has handled all of the two motor oil changes to date-13K miles total. As most of you veteran Expedition owners knew long ago (stupid I did not), Ford junked the Dipsticks (except in the mechanical department to save perhaps $1.50 per $62,000 vehicle) as any manufacturer knows owners are too dumb to attempt to understand the process.
So I called the dealership and was told that as of today (12/31/18) they have no shop time available to schedule till 1/18/19!!!! However if I left the truck some unknown days they can try to squeeze it in (wonder how long a Torque Converter replacement takes?).
I have spent the last several hours researching this website on the topic but most Expeditions discussed are much older and way more than my 13K miles, so if any of you folks have a newer unit with a similar problem please call out! (oddly this seems to be a relatively common problem on the 2018 10 speeds than later 3rd gen 6 speed trucks on this site). Ford did not seem to have a relevant TSB on 3rd Gens with this issue either, but I doubt I am the only one that could have this problem.
HELP!
I can’t offer you much, this issue of shuttering and rumble strips was seen occasionally on 07-08’ 6R75 Expedition transmissions as well as some early 6R80 transmissions. Was usually solved with a transmission fluid change (worn friction modifier) and or a misfire fix.
Can’t recommend this for your 17’ as it’s a different powertrain and transmission altogether than the earlier 3rd gens. We try to separate the 07-14 and 15-17 trucks and not mix match common fixes and repairs. Too many differences, I’d bet your dealer will be your best bet. Unless another 15-17 owner has experienced the same and can help...
Rumble strip and shutters from the transmission could be caused by misfires on earlier 3rd gens (worn plugs, bad coils). I’m not sure if the ecoboost and it’s transmission would act up from misfires the same.....again different trucks with different symptoms when something’s wrong.
J
jrc50
Mobile, Al.
HELP!
Ok, drove it to the dealer today, truck repeated shuddering several times on the 2 mile drive. They confirmed they had an 18 day service backlog and offered 0 sympathy. We will see it their attitude improves any, salesman offered to intervene if they do not at least get me a date in a few days. It is hard to believe that this is the only 3rd Gen Expedition with this issue. I have a feeling that when they get around to checking the transmission fluid-since the shuddering seems worse going around a turn-that issue is either fluid level or something causing fluid to starve-however since Ford saves a few pennies on eliminating the trans dipstick there is no way for the consumer to do even this simple check!
bobmbx
The sudden onset of your symptoms points more towards a bad coil than a tranny issue, also by the intermittent nature of the symptom. Do you have a scanner (a good one) that can show you total misfires per cylinder? It takes a large number of misfires before the CEL comes on.
bobmbx
J
jrc50
Mobile, Al.
Unfortunately, I do not have a scanner, probably should but impact of shudder is pretty severe so it is certainly possible in being a bad coil but I cannot figure out how taking it out of Drive to M cured it the other night. Any idea how common bad coils are with 3rd Gen Expeditions?
bobmbx
Haven't heard much on this forum about systemic coil failures on '17s or early failures like yours, if it is a coil thats bad.
TobyU
Ohio
A coil misfire will be a lot more noticeable in higher gear or overdrive gears. But if its that bad the check engine light should have been flashing.
You should go ahead and get a scan tool as they are available online from china for under 20.00
Always nice to have a good idea where to start looking.
jeff kushner
North of Annapolis
I'm just getting ready to exceed the PT warranty at 57,000 miles and haven't felt what you're experiencing and I think it might be a first, if indeed the tranny is bad so please post back.
(I)Enquiring minds want to know!
jeff
Mine shuddered and was dropping in and out of overdrive. The coil on cylinder #8 went bad therefore a misfire was present. The check engine light did not come on until later when I took it to the shop. The shudder went away when I hit the O/D off button. Mine is a 5.4L 3V Triton/ 6 Speed, so not related to the OPs truck which is why I didn’t post my past experience. Just sharing this because the misfire didn’t throw a CEL in my case.
Sorry I’m of no help, again different powertrains and drivetrains.
J
jrc50
Mobile, Al.
No help here, of course, as my '17 XLT 4x4 has not exhibited these symptoms. I have 14,000 miles on mine and it was probably built within a month of yours. Last 5 of my VIN is 585xx if that helps.
-- Chuck
Mine is 542XX
J
jrc50
Mobile, Al.
Interesting even though completely different powertrain and age shudder both went away when taken out of overdrive
J
jrc50
Mobile, Al.
Update
Since it had been 3 days in the dealership with no word I contacted my salesman to intercede with the service department as I had not heard anything from anyone there and I was getting pretty steamed up and figured it best to get a 3rd party involved in the discussion to make any progress. Much to my surprise and satisfaction, when the salesman checked my Expedition was in the air with the transmission Valve Body labeled as the cause of the shuddering!!
I thanked the salesman for checking and he as well as I were shocked the shuddering actually was the transmission given the many years this 6 speed has been built though I had guessed that to begin with. The long manufacturing and service life this unit has had in Expeditions was one of the reasons I bought this (as opposed to a 2018 with a 10 speed new design) in the first place-so much for that logic.
If I learn anymore about specifics I will add it to this site "knowledge base". Thanks for everyone's input.​
J
jrc50
Mobile, Al.
Update
Ok, picked Expedition back up today (1/7/19) pm. Seems to run ok, shudder gone, shifts snap nicely. Parts required besides fluid: AL3Z-7G276-D (valve body I believe) and 6L2Z-7G276-AA Connector along with 7 quarts trans fluid XT-10-QLVC
This valve body part number is listed to have been built from 2014-2017 so it is nothing new. No explanation voiced by dealer why it failed. Bill was $00.00 which was the only redeeming thing about this event, just glad it did not leave my wife and I on a very dark 40 mile journey between Florida and Alabama after midnight with any number of poor cell zones.
holeintheice
Lino Lakes
A little late the the party but the clutches in the converter dry out and chatter. If you put a bottle of Ford Friction Modifier in the transmission fluid, Chatter should go away in about ten miles. I work at a Ford dealership. Have a 17' myself and same issue when i bought at 98,000 miles. I did buy a warranty through Ford as rather have it and not need it than need it and not have it. Planning on driving it till needs a whole new unit though. Best of luck.
