Your wdh is NOT setup correctly. My trailer has a measured 900 pound tongue weight (tanks full of water) and my 17 expy only squats 1" in the rear from unloaded, and I have leaking rear shocks according to Ford from my recent oil change. Either your hitch height is wrong, or you don't have enough tension on the spring bars. You can raise the saddles on the trailer to put more tension if you have a flat bar type hitch, or go up more chain links if you have that style hitch. I have to use my power tongue jack to lift the trailer and rear of the expy pretty dang high to muscle my bars into place but it works well.
