2017 Expedition w/ 3.5 Ecoboost -- engine sounds? (video included)
jrq2a
I've been a longtime expedition owner ('03 w/ 240k mi on it; love it but have finally succumbed to the head gasket external oil leak on passenger side and know that I'll need to rebuild and/or replace at some point) and am on the hunt for another, later model expedition el. I've found a 2017 expedition el limited with 120k mi on it, and I received a video of it running from the seller. I have read up on the cam phaser issues, timing chain issues, etc with the 3.5 ecoboost and have watched several youtube videos of engines exhibiting the associated sounds. Despite this, I'm really having trouble determining whether this prospective expy 'sounds' like it has a problem or not? I know cell phone videos are not known for their great audio, but still -- to me, this engine seems oddly loud and rattly. The seller mentioned that the engine is much quieter than the video apparently indicates. Anybody care to weigh in on this and help me determine whether this expy is worth the drive to purchase? (3.5hr drive for me... unfortunately this used auto market isn't giving me any good closer options)...
I'm new here and can't quite figure out how to link or embed a video. I did post the same question and video to the expedition forum at reddit for feedback too. So the video should be easily accessed there: https://www.reddit.com/r/fordexpedi...expedition_w_35_ecoboost_engine_sounds_video/
Thanks in advance for any input folks can provide,
Jesse
2020FordRaptor
Nevada
That definitely doesn't sound normal. If the price is really cheap go for it, otherwise could be a rabbithole I wouldn't go down.
JasonH
Houston, TX
It sounds funny, I would pass. Cam phaser noise is only on startup. The high pressure fuel pump is noisy, but I'm pretty sure it's not that bad. Repairs on these vehicles can be expensive. I suggest getting something with lower miles that can be warrantied.
J
jrq2a
Thanks everybody for the quick feedback; definitely affirming that I may have to just pass this one up and continue my search...
Timo2824
Wichita
Sounds like the injectors and high pressure fuel pump just being caught by the mic on the phone. I would go and listen to it in person if it's close.
J
jrq2a
Good point. I did ask the seller if he could take a video from a little further away from the engine itself, in case the cellphone was simply amplifying certain tones in a weird way being as close to the engine as the phone was.
Unfortunately, I'm a 3.5hr drive from the seller, so a quick stop by to hear it in person is out of the question... hence me now having to dissect the only video evidence I have at the moment :). Awaiting another couple videos at the moment from him.
Steve Tanner
Arizona
I think the phone audio is amplifying things strangely, but honestly that sounds exactly like my 2017 with 73k on it. It's just as Timo2824 said - high pressure fuel pump + injectors.
I was concerned when we first got it because I thought it sounded a bit "diesel-y", but every '15-'17 I have ever heard sounds like that. My worry would be how much carbon is built up on the valves if they don't have a catch can.
J
jrq2a
Thanks -- you mentioned catch can... In the research I've done, I came to the conclusion that they started putting the dual injection (port + direct) ecoboost 3.5 in the 2017 expeditions, which is a major reason i'm looking specifically for a 2017 model (in addition to the six speed tranny instead of the more recent 10 speed). Do some 2017 expeditions not have the ecoboost 3.5's with the additional port injection?
GlennSullivan
NY & FL
I have a 2017 Limited and that does not sound like my engine. I would say exhaust manifold gasket leak, but don't know what a failing high pressure pump sounds like.
klaus2014
Washington DC
The 2017 F-150's got the next gen ecoboosts but unfortunately the Expeditions didn't get them until the redesign in 2018, so there isn't port injection in any of the 17 expeditions sadly (unless my research a few years back was wrong). Personally okay with it since those next gen ecoboosts have been known to eat cam phasers every 60k miles. You can have clean valves on the former generation EB with a catch can for a fraction of the cost it would be to have the dealer tear into the newer engines to replace phasers ;)
rndlmn4
Illinois
If you think it may be the way the phone picked up the sound, you might try this. Ask a friend, or a local Ford dealer, to let you listen to a 3.5 EB idle. Record it with your phone from 3 ft, 5 ft, and 10 ft away. Listen to the recorded sound file and see if it sounds similar. As an option to that, go to a service garage - not a Ford dealer - and ask how much experience they have working on the 3.5 EB. Have them listen to the recording. The shop I go to has a lot of experience with them. The owner drives one and the shop services our county's police vehicles.
FWIW, my 2015 has 76K miles and doesn't make that sound - at least not obviously to the naked ear.
