Charles M
I have a 2017 Ford Expedition Limited with 84,000 miles on it. I purchased it used 1 year ago.
It runs good although I had to have transmissions lines replaced a couple of months ago and I just replaced the front rotors and brakes.
This morning I started it up and turned it around in the drive and it ran fine. A couple of hours later I tried to remote start it and it started then stopped. When I got in and started it was a slow crank but started. The speedometer kept bouncing up and down and the left and right digital dash screens were coming on than going off and all the warnings lights came on and off. The Sync screen said "Network Communications Error". The truck ran fine, I drove it around the block but it was blowing hot air now, the AC didn't work but all the gauges where working. Decided to take our other care to the store.
Came back about an hour or so later and started up the truck and everything came on just fine. I went to look at the batter and cables and there was a bit of corrosion. Figured it was time for a new battery. As I was driving the truck to Auto Zone, the digital readouts started come on and off again. The Sync screen went off and the Air Was blowing hot air and would turn off when I turned of with the button.
I replaced the battery at the auto parts store cleaned the positive terminal cable attachment and installed the new battery. When I started the truck again, same thing. Runs fine, gauge are sporadic, Hot Air blowing full blast and sync screen is off.
Not sure what to do at this point. Not sure even how to approach troubleshooting this. Currently I have the negative cable off the battery while I search around for some guidance.
Haven't found any issues like this on the internet for reference.
Any advise or wisdom would greatly be appreciated.
