17LimitedExpy
Thanks for the reply. I like that I then have more options on the blade this way. Do you know if the mounting hole on this arm (for the motor shaft) has a tapered brass metal insert with splines? I guess there's no harm in trying it, but what gives with the Ford part (the one I ordered) having a smooth bore with nothing for the splined shaft to engage with? The one that came off clearly had a tapered brass insert.
The Dorman arm from Amazon comes with a tapered brass insert that is smooth. Once you install it and tighten down the nut, the metal splines from the Expy mount form a very tight connection with the brass insert on the wiper arm. It's easy to install and has held up well...and it is flexible/moves enough to easily lift the wiper blade from the back window to make cleaning very easy...something you can't do with the stock wiper arm.
