What were the symptoms of water pump failure.Did the water pump on my '16 last fall, my word of advice is to be careful with the plastic turbo tubing when you remove it, I cracked one of mine, it was over $300 for a replacement and I couldn't find one used, so I used two part epoxy to repair it. Also, I did the main serpentine belt while I was at it... you're there anyway, might as well.
