Agree with DL, I drove the '16 Armada and turned around within a half mile....hated that truck. Small and fugly!
As far as the turbo/NA discussion goes. Like many here, I grew up in the era of the 60's muscle cars. Real strong V8's with 850 dual feed carbs. Everything was "user adjustable" and we were comfortable with that because we knew that we could repair it if it required a repair. While most of my friends wrenched cars, I did bikes and we both watched as component reliability sky rocketed. Today, we just don't have to worry about failures like we used to. Most computerized systems really will outlast the 200K I expect to get out of a car. My SLk for instance has over 190K on it and thee only thing that has ever failed is the original battery, after 12 years! Electrics last today, as long as we can keep them dry!
I did my homework on this 3.5 twin turbo and since I have a turbo-bike, I already knew a bit of what it takes to keep them spinning. On my bike, the 38mm turbo spins at 230K rpm....yeah, two hundred and thirty THOUSAND rpm fast!
The compression and timing both have to be reduced/retarded under full boost to prevent detonation which the 3.5 does by keeping the CR at a reasonable 10:1 and adjusting the timing on the fly. The only thing I see needing service over the course of 200K miles is the turbos themselves. I have rebuilt my bikes turbo before I modified the setup to run at 18PSI. They spin in an oil bearing so dirty oil is going to be a very real no-no for my new truck unless I get longing for doing another turbo rebuild. Ford also sets the system up to produce a fairly low 11-13PSI boost pressure & keeps them spooled by using a small exh port size on each header section. This keeps them spinning fast enough to make boost (higher than ambient pressure) at very low engine rpm while eliminating turbo-lag. It's a pretty slick setup that give two big benefits in low total boost and an "always ready" condition. In the world of boosted engines, we see things like broken intake manifold bolts, bent con rods and piston melting from detonation and over boosting and NONE of these things has been seen with the 3.5's. The balance of the engine seems to be very strong as as others have already mentioned, it's worlds stronger & faster then my old 5.4's that I had in my 2 previous Expys.
I tend to be more comfortable with "old school" so I understand that position but I am sold on this engine, 100%.
jeff
