2020 Expedition Sync 3 screen goes black
SamIAm235
Midwest
I have searched this forum and have seen there are others with similar issues but not exact. Occasionally, the Sync screen will go black, the sound will shut off, and I will have to reset by holding power and fast forward button. Once I do this, everything works fine. This seems to be happening more frequently. It's really annoying as I have to hear my wife complain about it as this is her vehicle. It appears everyone points to the APIM. The vehicle is out of warranty. Any suggestions for an inexpensive test and fix? All the threads say the manufacturer has the AIPM on backorder, which tells me this is a bigger problem than they will want to admit.
Mr Big
Tampa Bay, Florida USA
Have you recently performed an update? Was it OTA or 3rd party? What year is the vehicle? If you have recently performed an update, especially 3rd party, a factory reset may fix the issue. You will most likely have to put all your settings back in. But this sometimes fixes anomalies after an update.
Judah144
Minnesota
I had the same issue. Fortunately for me, I had an extended warranty and took it into the dealership to have the AIPM module replaced. The total cost for the repair was $1300 but I only had to pay my deductible.
sixstring
Florida
What version sw is on your nav system? Ford came out with with an update a month or so ago that helped with the bad apim. The current release is 3.4.23188. You can get it at https://www.ford.com/support/sync-maps-updates/ . It doesn't fix a bad apim but it helped with some problems to at least stabilize some problems. Might be worth the check.
gmanater
United States
I have a 2020 Expedition Max and have the exact same symptoms. The first time it occurred was about Oct 10th, but a restart resolved it. Since Oct 21st or so we have to do the Power + Forward hold down. It happens randomly, for some reason more for my wife...
Mine is on the auto update via WIFI at my house, so I assume it was a recent update. I will check the version and get back on it.
VBreithaupt
Mine was doing the same and the dealer is fixing it along with other things. Not sure if they are just updating or new parts. I will see when I get it back. Along with going black mine would drop my hot spot and I would have to reset the whole system.
bobnely
US
I had the same problem but like @sixstring said a new update came out a month ago and so far no more problems.
gmanater
United States
Looks like I was not on the latest update. Did the USB update last night and will report back if issue continue. FYI update took about 15 min or so to apply on my 2020.
tweakeraz
Arizona
I had the same issue as well. Also had slowness in the interface. Dealer replaced APIM under warranty and no issues since.
