2021 Expedition Brake Bracket Torque
Willie G
I am going to replace pads and rotors (front and back) on a 2021 Expedition XLT. RWD. I know how to put the EPB in service mode and take it out of service mode. The simple thing I need is the torque for the: 1)Front Brake Caliper Bracket Bolts. 2) Front Brake Slide Pin Bolt Torque. 3)Rear Brake Bracket Torque. 4) Rear Brake Slide Pin Bolt Torque. I know I don't have to remove the rear caliper brackets, but would like the info anyway. Yes I clean the bolts and use orange locktite on all the bolts. What I have gathered the front brake caliper bracket torque is a 184 ft. Lbs. The slide pin torque for those bolts is 25 - 30 ft. Lbs. Just want to confirm my suspicions. By the way orange locktite is stronger than blue and can be removed with hand tools. Full strength set is 24 hrs for this stuff.
HazBeen
Great Lakes
Attached here and immediately below, from the 2021 Expedition Workshop Manual...
  • Front Brake Disc - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Front Brake Pads - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Front Brake Caliper Anchor Plate - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Front Brake Caliper - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Electronic Parking Brake (EPB) Service Mode Activation and Deactivation - General Procedures -...pdf
HazBeen
Great Lakes
Good luck!
  • Brake System Pressure Bleeding - General Procedures - 2021 Expedition Workshop Manual.pdf
  • Rear Brake Caliper - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Rear Brake Caliper Anchor Plate - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Rear Brake Disc - Removal and Installation - 2021 Expedition Workshop Manual.pdf
  • Rear Brake Pads - Removal and Installation - 2021 Expedition Workshop Manual.pdf
