osteodoc08
was thinking of changing the transmission, transfer case and diff oils now that I’m at 30k miles as preventative maintence. Oils are cheap, unseen water intrusion or other issues leading to failure is not.
Not when most places do the trans service!! This is why I hate the invention of the flush machine. It's nice to get most all of fluid out but you can run more through until you have replaced all same as they do....BUT it is MUCH MORE important to change filter and clan pan.
They made the machine to make it easier for them, THEN charge more and act like it is a better service.
Still pretty hard to get the fluid out of the torque converter by just dropping the transmission pan, so a combination of cleaning the pan/replacing the filter screen and then doing a full flush seems like it would be ideal to get all new fluid in the torque converter and still get the debris out of the transmission pan.
The problem is there is no tranny dipstick (hehehe) to confirm tranny fluid level and no easy place to add the fluid. Last I saw the fill hole was on top of the tranny and difficult to get to.
