#3rd gen front end alignment specs?
plumcolr
freehold nj
With coil spring rear suspension, the total front wheel toe is +0.14 degrees, plus or minus 0.20 degrees. In other words, almost no toe. From the factory repair manual.
PS: If you fool around with the caster / camber, be aware the adjusting bolts are to be tightened to an eye-watering 258 ft lb. Anything under 200 and they will move.
