5.4 Triton rough at 1700 rpm
Colorado Ford
Colorado
I have a 2005 EB Expedition..about 125,000 It is running rough when pulling a hill around 1500-1800 rpm. When it kicks down it runs smooth and also smooth at idle. I have also noticed a drop in mileage. I am thinking it may be a vacuum leak. Anyone know where I can find a diagram or other thoughts? Thanks
CARO'S98EB
florida
A vacuum leak would make it run worse at idle not when accelerating. Sounds like a ignition miss. 05 also had problems with injectors- even had a recall but I think it was only to 100,000 miles.
masterhacker
Wisconsin
Computer wont pick up miss unless its pretty bad, mine wont anyways ive been having issues with my coils obd wont pick up a miss unless i really get on it
masterhacker
Wisconsin
also to find vaccum leak take carb cleaner and spray a little by the vaccum lines, if idle changes you have a leak. be careful its flamable
C
Colorado Ford
Colorado
Threw me a code today, but pretty generic....P0420....left bank efficiency below threshold...could be the coil packs(which seem pretty common on that side), EGR, O2S, Cat, Vac.....I guess I will start with the coil....any other thoughts?
