6 lug hub for obs expy?
AD1993
Louisiana
I have a set of 2020 raptor rims and I was wondering if anyone knew if the later model hubs with 6x135 studs would fit on the 1997 expedition. Or if anyone had and info about something like this.
Thanks
Hamfisted
Ft Lauderdale
You can get 5-lug to 6-lug adapters pretty easy, and use them that way a lot cheaper. Check the center hub diameter before you order to make sure the center bore hole on the adapter will fit.
Ford 5-Lug to 6-Lug wheel adapters on Amazon
Assuming its a 4x4 Expy. The bearing numbers are the same for 5 or 6 lug hubs.
But you need rotors and calipers as well. It gets very expensive very fast.
I haven't heard of anyone on here doing it.
