Fizzy
Got a recall notice about the PCM reprogramming. Whilst it was in I had them check the transmission and why the coolant needs topping off before each 5 month service.
For the transmission, it was being clunky between 3 and 5, and sometimes up around 7. It would also sometimes lurch from P to R or D. Tech had a look and said he'll order the parts for a rebuild, including the redesigned CDF drum. Having watched a bunch of trans techs tearing down and putting back together transmissions, it's incredibly complicated. Trans techs are a different breed. I worry that a regular Ford shop tech isn't skilled/experienced enough to do this work, but I guess it is what it is. They probably do a lot of them.
As for the coolant, I've noticed that before each 6 month service, the coolant would be at, or just below, the MIN mark. I'd have to top it up myself with the red coolant from Ford. Tech had a look and couldn't find any leaks, but said the water pump is "sweating", so he's replacing that. I'm not convinced, but he didn't find any leaks. I have noticed when it's sub-zero out that the exhaust is quite smoky. My BIL has a similar age Navigator, and when we start them up at the same time in winter ours is smokier for longer.
Not really sure where I'm going with this. Happy it's being looked at under the original powertrain warranty and ESP, but also unhappy it needs to be done at all.
