Hi everyone,
So I have a 97 expedition with the 5.4L and am having a problem figuring out an overheating problem. Mainly, I'm just asking for some advice from those of you that know these engines better than me. At first I thought it may be a stuck thermostat so I pulled it out and found very brown, rusty water inside. I put the thermostat in a pot of boiling water and it only opened a crack...not even a 16th of an inch. I figured it was bad so I flushed the engine coolant out (thanks to the previous owner who had put one of those prestone flush adapters in the heater line), added fresh coolant with the front of the truck up on ramps and ran it without a thermostat to see what it would do. Sure enough, the temp gauge started climbing rather quickly for an engine with no thermostat and after a 2 mile drive, was getting close to the overheat mark with no hot air out of the heater. My next step was to let the engine cool down. I then took the cap off of that flush adapter and hooked a short garden hose to it. I made sure the cooling system was full and started the engine and nothing came out of that heater hose. Not even a drop.
This is leading to believe that my water pump isn't pumping anything. I don't think it's a totally clogged radiator because I had a garden hose hooked to that flush adapter and the drain plug open on the radiator and water was flowing rapidly out that drain plug hole. Does anyone have any other thoughts on this before I go spending money on a water pump and more coolant?
Thanks in advance!!
Thanks in advance!!
