'98 Expedition suspension schematic?
Poochie
Hi All
I'm posting this for my 76 year old father who owns the Expedition. He just had the truck in to the dealer to fix some horrible noises coming from the front end which turned out to be worn out sway bar bushings. The truck sounds much better now! He would like to see a schematic for the front suspension on the truck. Would anyone have one that they could scan in and email to me? He will never be working on this truck himself, so it doesn't make much sense to buy a factory manual for it.
Cheers,
Ken
F150
I've attached it in a MS Word document.
Let me know if you can find/open.
:cheers:
G
Guest
I just had to replace the sway bar bushings on mines, with just 50k miles. It is a easy process and the part was less than $25. I would like a copy of that manual also, if you don't mine.
Thanks
P
Poochie
Looks like I need another coffee, F150. I can't seem to find the attachment.
I'm feeling a little dumb right now......
F150
My fault. I did not realize that you could only attache certain extensions. I put the related text to the attached .gif files below. Let me know if this works.
Item Part Number Description
1 — Front Axle Hub Nut (2 Req'd)
2 3K185 Front Wheel Knuckle—
(2 Req'd)
3 3083 Front Suspension Upper Arm— (2 Req'd)
4 3467 Front Suspension Upper Arm Ball Joint Shield (2 Req'd)
5 3B236 Front Suspension Upper Arm Adjusting Cam and Bolts
(2 Req'd)
6 N805480-S427 Front Suspension Upper Arm Nuts
7 N811538-S301 Front Suspension Lower Arm Bolts
8 N800237-S427 Front Suspension Lower Arm Nuts
9 N811083-S301 Front Shock Absorber Lower Nut (2 Req'd)
10 3051 Front Suspension Lower Arm (2 Req'd)
11 3A078 Front Suspension Lower Arm Ball Joint Shield (2 Req'd)
12 N808403-S426 Front Shock Absorber Lower Bolt (2 Req'd)
13 5B326 Torsion Bar (2 Req'd)
14 5B328 Torsion Bar Adjuster
15 18124 Front Shock Absorber—
(2 Req'd)
16 N800594-S100 Front Wheel Driveshaft and Joint Bolt
17 3B436 Front Wheel Driveshaft and Joint
18 1125 Brake Disc
The front suspension components are:
front suspension upper arm (3083)
front suspension lower arm (3079)
torsion bar
torsion bar crossmember support
front wheel knuckle (3K185)
front shock absorbers (18124)
front stabilizer bar (5482)
front stabilizer bar links
wheel hub (1104)
front axle bumper
The front suspension upper arm is a single wishbone type. It contains the upper ball joint and is replaced as a unit.
The front suspension lower arm is a solid die cast arm. It contains the lower ball joint and is replaced as a unit.
The torsion bars connect the front suspension lower arm to the torsion bar adjuster. The torsion bar adjuster allows setting of the proper ride height. Torsion bars are not interchangeable; the ends are stamped R for the right side or L for the left side.
The front wheel knuckle connects the front suspension upper arm and front suspension lower arm ball joints. It controls lateral movement and pivots to allow steering. It holds the disc brake caliper (2B120) and the wheel hub.
The front stabilizer bar is connected to both front suspension lower arms and controls side roll.
For additional information on vehicles equipped with 4-wheel air suspension, refer to Section 204-05B .
1 5495 Front Stabilizer Bar Link Bolt (2 Req'd)
2 5493 Lower Suspension Arm Stabilizer Bar Insulator
(2 Req'd)
3 5482 Front Stabilizer Bar
4 5486 Stabilizer Bar Bracket
(2 Req'd)
5 N811095-S426 Stabilizer Bar Bracket Bolt
(4 Req'd)
6 5K483 Front Stabilizer Bar Link
(2 Req'd)
7 18198 Shock Absorber Bushing Repair Kit (2 Req'd)
