Here's the scenario: Expy was running fine. I stopped
and filled up with 93 octane fuel at a gas station that
gets heavy traffic. Left the gas station and less than
a mile later it started to bog down when I stepped on
the accelerator. Made it home, shut her down and then
she wouldn't start. She cranks and makes an attempt to
start and then just stalls. I checked the fuel pressure and
there was less than 10 psi with the key turned to on. When
cranking it shoots up to 35 psi. The relay is good and so
is the fuse. I replaced the fuel pump thinking that was the
problem and still have the same issue. Checked the fuel inertia
shut off unit and that was not the problem. Anyone have any
ideas?
ideas?
