Waljon
Hello new to this forum and seeking some help I own a 98 Expedition and have had it now several years without any troubles till just recently it started with after every fill up the CEL would come on but it would run normal at the time I had no code reader so I disconnected the battery to clear the cel and no light till it was filled again, now it has a bad hesitation seems to not want to go when you floor it revs to about 2000rpm then it will start to go. Well the other day my wife almost ran it out of gas ran it down pretty low and after that it started to miss everything seems to point to fuel pump or something with fueling so that is where I am going to start, what is normal fuel pressure for a 5.4 at Idle? also I used my superchip 1705 programmer for my diesel truck just to read the codes and I got P0174.
So far I have changed the fuel filter ran some injector cleaner and checked the notorious elbow for the PCV valve and it was fine.
Any Input would be greatly appreciated
Walter
Walter
