pprompun
1999 Ford Expedition 5.4 Litre
Symptoms: On cool day or park under shed on hot day - All A/C (front & rear) are OK. But on hot day and park under the Sun (when cabin temp. gets real hot) - Rear A/C blows very cold but front A/C blows warm for a while and would get very cold (work properly) after the cabin temp. get cooler, about 10 minutes.
Diagnosis: Have read lots of threads about the "Blend Door" & "Actuator" broken and stuck and ready to open the front panel. However, if the blend door and/or actuator are the problems, would the front A/C blow the same air temp. and not changing due to the cabin temp.
Would anybody experienced the same be kind to shed the light on this with explanation and solution (send to the dealer is not an option). I plan to spend the whole day this weekend (like previous thread said - most time will be spent to remove the front panel cluster to get to these units).
Greatly appreciate any help!
