atle
hey guys, been a long while.
So I replaced my a/c compressor, drier, orifice tube, low and high pressure switches. HOWEVER, the clutch is not engaging. What I've checked/tested:
1. all fuses and relay are ok.
2. put direct battery power to the compressor with engine off and got clicking
3. with engine on, direct battery power to compressor which engaged clutch so that I could charge system. (this worked as I was able to get 40 psi and 39 deg. at the vents). But once the hotwire was removed, the clutch still did not engage.
4. Jumped terminals at the low pressure switch and clutch did not engage.
So basically, no power to the compressor. What else do I check???
Thanks in advance.
Thanks in advance.
