a/c zones switching
ammolance
FL
Hello, did some searching and couldn't find a related issue. If i missed it, please send my way! 2003 Eddie Bauer, and the panel vents will fade in and out, and almost switch for no apparent reason. Had the same thing in my 2003 Marauder, and there are rings near/on the vacuum lines that were worn, replaced and cleared up the issue. Same thing with the Expeditions? Thanks in advance for any insight!
ammolance
ammolance
FL
Discovered today its when i accelerate. Taking foot off returns back to panel vents.
stamp11127
Temple, Georgia
Usual spot for vac leak is near / under the battery. Follow the line from the firewall to where it sources the vacuum, you'll find it if it is there.
