Anchorclanker
So recently my 08 had these lights come on and stay on each time I started to drive. I put my code reader on it and pulled "B1342 ECU fault". Doing some research I found it could be the ABS Module, a wheel speed sensor or possible ground or connection issues. Depending on where I looked I'd get varying opinions on the solution but nothing definitive to steer me to the problem.
I decided to start cheap and easy and check the fuses and relays. Using the manual, I pulled each fuse and checked connectivity. All good so I put them back in. Low and behold the lights were out and stayed out all day. Being as they had probably never been pulled before I'm thinking it was a connection issue with one of them, no idea which one though.
Just food for thought for anyone having these lights and code with no other symptoms.
Sent from my Pixel 3 using Tapatalk
