Adding Climate menu on Sync (XL/XLTs) | APIM | 7D0-01-01 | xxxx | xxx3 | xxxx | The following won't work on XLT w/climate: Max A/C, Auto mode, Temp (numerical) settings, Fan speed, Max Defrost |
APIM | 7D0-01-02 | xxxx | x2xx | xxxx |
Were you able to get the climate controls using FORScan? I'm looking also! It ****** me off that I traded in a 2019 with only 26K miles and a lot of things are missing and I have the same 202A package in the 21 that I did in the 19Currently own a 2021 Expedition Max XLT, trying to enable climate controls on my sync 3 screen. Any help here? Thanks
Much appreciated my friend! Where were you able to come across this info? I was getting about ready to give up! I have downloaded the info if you want to close the link back upI will leave my Google link open for a few days so you can download. I have done all of these changes.
Misc Forscan - Google Drive
drive.google.com
If you simply enabled Climate Domain under the APIM factory setting, why is everyone else changing the settings in the AS BUILT file? I have seen other settings changed by just enabling them in the Factory file, but not the climate controls and I was wandering if it was possible to do it there too.I will leave my Google link open for a few days so you can download. I have done all of these changes.
drive.google.com
